pianotuna
Sep 27, 2015Nomad III
Hi CA Traveler,
You would need to disconnect the battery bank and run the 'house' on just the converter. Almost always some charging is going to be going on. I wonder how power factor 'fits' into that equation. I know my PD is 0.7 power factor. Does that mean using 30% instead of 10?
CA Traveler wrote:
My thoughts on efficiency of the Kill-A-Watt approach. The converter is only used to supply house loads while on shore power so the Kill-A-Watt power used by the house loads would be higher the power used from the battery for the same loads. I’d probably use 10% for the converter. My Magnum ME2012 specification says 95% peak efficiency so I’d probably use 10% for it.
There are also efficiency in the solar system to consider like controller efficiency and weather, mounting, location, etc.
If I was going to consider efficiency I'd add 10% but overall I’d likely just ignore efficiency because I’d add a margin for the solar panels anyway. :R
