DrewE
Sep 28, 2015Explorer III
pianotuna wrote:
Hi CA Traveler,
You would need to disconnect the battery bank and run the 'house' on just the converter. Almost always some charging is going to be going on. I wonder how power factor 'fits' into that equation. I know my PD is 0.7 power factor. Does that mean using 30% instead of 10?
A Kill-a-watt can and does measure true power. I think most will also report the power factor, apparent power, and probably things like line voltage and frequency. Since they work by sampling the voltage and the current and digitally computing the (instantaneous) power from them, it's a small matter of programming of the little microcontroller brain to get all sorts of useful information like that which would have formerly required a bunch of fancy analog instrumentation.
