pianotuna
Sep 29, 2015Nomad III
Hi gator,
The solar calculator at that page require you to know how many watts you use per day. That is what we are trying to find out.
Here is a link to the rather special spreadsheet which includes an energy audit, that N8GS has created to help size solar battery charging systems!
solar spreadsheet by N8GS
If you use a kill-a-watt to record the energy used, then a lot of guess work may be eliminated. For example, how many minutes do you actually use the water pump in a 24 time frame? Is that a typical answer?
By the way, the calculator you recommend suggests I need 3400 amp-hours of battery bank and 34 250 watt panels. I'm afraid that won't be happening any time soon.
