CA_Traveler's avatar
CA_Traveler
Explorer III
Sep 26, 2015
Measuring Your Solar Needs – An Easy and Low Cost Method
While there are many posts on how to estimate your solar needs this method measures your usage using only inexpensive equipment which also has a lot of other uses.
Summary: Set up your rig with fully charged batteries to simulate a boon docking day but with power available. Use the $30 Kill-A-Watt device with adapters on the shore cord to measure your power usage for 24 hours. The watts-hours (Wh) measured would be the same as an equivalent boon docking day including DC device usage and AC device usage using an inverter.
This method then provides actual power usage which can then be used to determine the solar equipment requirement. If the usage was 1500 Wh for example then the solar could be sized to supply that power while boon docking.
Solar sizing is involved considering weather, location, mounting, time of year and other factors but at least the power usage requirements are know.
Details: The Kill-A-Watt device uses a 20A plug so you may need adapters for your rig. It’s limited to a maximum of 15A. It’s very important that your start with fully charged batteries so that you are not also measuring AC amps needed to charge the batteries. You are measuring Wh(or power) and as long as it’s equivalent to a boon docking day the Wh used are what you will need to replace in the battery.
Solar Sizing Example: For 1500Wh measured add a 500Wh margin for 2000Wh. Flat mount the panels and using 70% efficiency the solar power needed is 2000/0.7 = 2857Wh. Using 4 hours of solar yields 2857/4 = 714W. 3x 250W panels would be more than needed or perhaps compromise and install 500W.
Miscellaneous The Kill-A-Watt is a very useful device for measuring power from any plug in AC device and I highly recommend it. You can also leave it plugged in with no connected loads to monitor your rigs AC voltage. Use it in the rig or at home.
Updated to reflect Wh.
  • RoyB's avatar
    RoyB
    Explorer II
    My roof size is going to tell me how much solar power I will need haha...
    I can mount two 120WATT Panels in the front part of the roof on each side of my fantastic roof fan. Then I can maybe get a 240WATT solar panel across the rear part of the roof. That is going to give me around 480 WATTS of solar panels to use.
    I don't know how others plan to use their solar panels but for me they will be used to supplement my generator run times to re-charge my battery from their 50% to 90% charge state before I lose the high the high sun each day.
    My generator will run for about an hour to get my 50 AMPS PLUS initial charge current when the batteries first get hit with the 14.4VDC charge voltage. After that the DC charge demand tapers back to around 8 AMPS or so which means I can shut down the the generator and just allow the 20AMPS of DC charge from my solar panels to run until the high sun goes away in the rest of the day.
    My WATTS being used will be determined on how many batteries I have in my setup...
    Been living quite well using just 255Ahs of battery capacity for my one day/night run but want to increase that soon to two banks of 300AH's from each bank with one on my trailer and the second bank in the truck bed...
    We usually camp at places that all have generator run time restrictions in place so going solar is really going to help out in that respect...
    My DC Power demand will be restricted to what I can use coming from my battery banks... Using the generator is my first priority followed up by what I can produce from the solar panels. My absolute priority is start each evening with at least a 90% charge state on my batteries if I want to make it through the one day/night running the things we want to be running...
    Pretty simple for me figuring out what my solar needs will be haha... Two panels in the front and a bigger panel in the rear...
    Roy Ken
  • Usage is measured in watt-hours, or amp-hours. Watts is the instantaneous draw.
