NinerBikes
Jan 04, 2015Explorer
jrnymn7 wrote:
There seems to be some playing fast and loose with terminology, on the part of "4 stage smart charger" purveyors. They say an occasional "boost" charge will eliminate (or at least limit) sulfation... but if I understand correctly, the term used should be stratification.
On that note, how fast will any significant stratification occur, if one does not float there batteries over the winter months?
It is what it is, but if up in Ontario, where it's as cold as a welldigger's butt in the Yukon, the temps negate much chemical damage and activity. Which is why your voltage drops off so much in really cold weather and your cars won't start very easily.
Stir it up when the late spring arrives or the snow and ice melts.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
