NinerBikes
Jan 04, 2015Explorer
pnichols wrote:NinerBikes wrote:
propane prices in The Q For pnichols.
Thanks much for the pricing info link.
I'll probably fill the P-tank here in CA and we can usually make it through the whole trip without refilling anywhere else - 18 gallon tank.
However, we're noticing that the Quartzite nights are chilly now. I hope they start warming up soon - as we do keep the propane furnace on a low setting all night long.
We're going to do other sight-seeing in AZ after Quartzite, but hope to keep the altitudes low so we don't get into freezing nights if we wind up drycamping some of the time. Maybe we'll have to use the 12 volt tank heaters on this trip!
I'll look for a 100-130 watt portable/foldable solar system at Quartzite, but won't buy unless it's a "just right" system: The two panel sections wired in series instead of parallel and an MPPT controller that can be remounted and used back at the RV close to the batteries instead up out at the panels. Still haven't decided on poly or mono ... I'll listen carefully to the hype at Quartzite on this issue ... right now I'm leaning towards mono but am a solar-amateur on this.
If you follow rjfishing's posts on pricing at the Q, I can assure you you can save significantly on buying my lightly used portable system, and then still have money left over to buy and wire what ever charge controller your little heart desires.
When you go portable, you do pay a small premium for the package and the convenience, there's no way around it. Call it a "plug and play" premium, if you will. But with that plug and play comes not having to add other time consuming solar panel electrical projects to your already impossibly long "Honey Do" list while being retired.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
