- MEXICOWANDERERExplorer16.2 volts
10.8 volts
Current limited inrush.
Same dimensions as 29 and 36 amp
Except 1-1/2" taller
50% greater air movement cooling fan
Stackable
Twice the heatsink area and twice the capacity size transistors versus 36 amp model.
Details dribbled in via several emails... - jrnymn7Explorersj,
You could use two of them in parallel, for a C4 rate, provided you have adequate 120v available, and if they go to at least 15v. And you could run one thru a booster (or bucker) for EQ'ing. - sjturboExplorerMW, this sounds like a better option than the VEC1093 for my bank of 4 CR235's don't you think?
BTW I want to thank everyone for their help with my various posts this past year and wish everyone a very Happy, Prosperous, and especially a Healthy NEW Year!!! - jrnymn7Explorersweet!
- mena661ExplorerOoooooooh! A 60 amp STACKABLE MegaWatt? MEX, did he mention the voltage range?
- MrWizardModeratorit IS when Mexi uses it
- Dakota98Explorer
MEXICOWANDERER wrote:
A sixty ampere voltage adjustable charger power supply. Knowing Megawatt, this is going to be a heck of a unit. I sent a reply to John Marles, inquiring about stackability
I don't permit a Chinese engineer directing an Indian programmer to diddle my batteries.
REPLY FROM JOHN MARLES ABOUT STACKABILITY (An Edit)
"Yes it is stackable.
Thank you,
John"
"Diddle" ---- Haven't heard that one for a while :B
Is that now, a technical term related to batteries ? - MEXICOWANDERERExplorerA sixty ampere voltage adjustable charger power supply. Knowing Megawatt, this is going to be a heck of a unit. I sent a reply to John Marles, inquiring about stackability
Thank you,
John" - 2oldmanExplorer II.and this is what?
