BFL13
Oct 08, 2017Explorer II
The specs for my PowerMax 100 amp PF-corrected converter include:
" •Max inrush current, single cycle: 40 amps"
Some years back I tried to get some use out of that info wrt why the issue thermistor kept frying (since resolved--they now come with a different thermistor), but Salvo (wherever he went) said this was useless info being for a single cycle on the sine wave or whatever it was--I was lost by then. :)
Anyway, I do run the 100 amper with my Honda EU3000is, and it is not so clear what happens at different times, if it is in-rush or running VA.
You have two things: A. the motor can conk out, or B. The motor can keep running but the circuit breaker can pop (so you have to shut off the motor and restart it to reset the CB)
On very cold mornings, I can start the Honda in Eco and plug in the 100 amper and the motor will conk out. OK so I learned to start it and let it warm up longer. I also leave it with Eco-off until after the 100 amper is running ok.
You can also pop the breaker with too much of a load. Sometimes the breaker will hold for a few minutes and then pop. Or it can pop right away. There seems to be a relationship between the CB popping or not, and whether the motor is in Eco or not. Can't understand that, but I think it is true. (I have only had this gen for 14 years and still have not figured out what's what with it.)
Anyway, the thing to do on cold mornings is to start it with Eco off, let it warm up a bit, and then plug in the 100 amper (it has PF correction), wait till it is all going Ok, then plug in the non- PF corrected 55 amper, and see that the Trimetric is showing 155 amps. Wait a bt to be sure, and now turn the Honda to Eco. Stays Ok from there on.
I have no clue about what is in-rush and what is just running VA required, and what is motor and what is CB or what combo of those is in play. But that is what I have learned to do "in the field--the hard way" :)
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
