MEXICOWANDERER's avatar
Oct 07, 2017
Megawatt Inrush And Small Generators
In the interests of accuracy I have copied John Marles, comments verbatim and they appear below
"Inrush is 50A/115VAC 50A/230VAC for a few milliseconds on the S-400 and S-350. Its controlled by duel thermistors. For the small generators some large start caps would solve the problem as long as those don't trip the generator while charging"
Thank you,
John
My comment...
Choose RUN capacitors, switch power to them first then enable the power supply. It's a great aid to ease startup current burden.
RUN capacitors are not expensive
http://www.surpluscenter.com/Electrical/Capacitors/Motor-Run-Capacitors/50-MFD-370-Volt-AC-Run-Capacitor-Genteq-22-1358.axd
No RepliesBe the first to reply
