CA_Traveler's avatar
CA_Traveler
Explorer III
Jun 22, 2015
Members Solar Installations With Pics
Dec 2020 Update: No recent installs are avaiable, some links may be invalid or missing pictures and some of the equipment is dated. However these links provide a lot of useful information.
This information can be valuable for ideas on solar installations. I have added the recent ones that I’ve found. Let me know of additional installations (please supply a link) and I’ll add them to the list. I’m also adding a brief summary including installation date for each installation.
AlbertaNewbie installation 250W, flat, Morningstar MPPT-45 controller, 6/14
Heap64 installation 500W, parallel, flat, Morningstar MPPT-45 controller, unique battery box, 6/14
anutami installation 200W, parallel, flat, Sunsaver MPPT, 9/14
CA Traveler installation 750W, serial, flat elevated, Morningstar MPPT60 controller, remote, Trimetric monitor, 12/14
Robertaloto installation 120W, flat, TC popup roof, Morningstar 20L controller,2/14
TechWriter installation 735W, MidNite Solar Classic 150 controller
BruceMc installation 160W, flat, Morningstar PWM 45, 8/14
JimM68 installation 600W, tilt, MPPT 60, 7/15
Buzzcut1 installation 200W, flat, Renogy PWM, 3/15
rjxj installation 520W, flat, Bogarts PWM, 7/15
Rbertalotto installation 280W, flat, Bogarts PWM, 6/15
CJW8 second installation 500W, flat, Rogue 3024 MPPT, 9/15
TheWB 100W, flat, Renogy Adventurer PWM, 11/15
scrubjaysnest Installation 360W, 4 way tilt+ portable, Morningstar TS-45 PWM controller, Trimetric monitor, 5/15
Oz Installation 100W, portable, Bogart SC-2030 controller, 4/16
Fisherguy Installation 480W, flat, Morningstar TS-45 PWM controller, TS-RM-2 display 8/15
wannabegone Installation 240W, tilted, Morningstar TS-45 PWM controller, TS-RM-2 display, 9/16
hedge Installation 300W, flat, epSolar PWM controller, 10/16
marcsbigfoot20b27 Installation 360W, tilt, 30 MPPT controller, 3 new AGM deep cycle, 8/17
_________________________________________________________________________________
Updated information from the previous thread - Forum Members Solar Installations With Pics. I’ll add comments as they are received.
sleepy's installation 200W, flat, parallel, HeliotropeHPV-22B controller, 11/09
2oldman's installation 810w (6@135w), tilt, series, Outback 60a controller, 8-12v AGM
Fire Instructor's installation 2 panels, tilt, Rogue 3024 controller, 2011
CJW8's installation 405W, flat, Rogue 3024 controller, 6/11
WanderMan's installation
renoman69's installation 270W, tilt, Blue Sky 3024i, 6/11
JManatee's installation 390W, tilt, Blue Sky 3024i
Mello Mike's installation
nina_70's installation
MrWizard's installation
sonicsix's installation
bigfootford's installation
Dave 1131's installation
smkettner's installation 675W, serial, flat, Morningstar MPPT60 controller, 2/12
watchthebox's installation
SCVJeff's installation
CallThisCamping!? installation
sabconsulting's installation
CrazyCooter's installation
RickSo's installation
garyhartz's installation
bogen2's installation
Jersey Shore's installation
12thgenusa's installation
Grodyman's installation
CA Traveler's son's installation 160W, flat, Morningstar Sunsaver 10L, 6/12
steve8679's installation
cruz-in's installation
Heynow999's installation
MARLANDO's installation
Tom M's installation Unique side mounted panels
BFL13's "Contraption"
marcindy's installation
  • 2oldman,
    Are you also using 24V battery bank? If so I'll add that as it's unique.
  • JiminDenver wrote:
    It would be nice to see this become a sticky.
    I've been wishing that there was a separate forum for "Solar." Or at least a separate category within Tech Issues.
    Wayne
  • Mine is: 810w (6@135w), tiltable, series, Outback 60a controller, 8 -12v AGM
  • Here are a couple of pictures that I took while recoating the roof on my 97 Bounder. Some of the panels date back to the 1994 installation on another 85 class C, and where moved to this RV back in November of 96.
    The two large panels where my 'new addition' in the winter of 99, on sale for 'only' $429 - 120 watt panels. Still producing power some 16 years later!
    Golden_HVAC wrote:
    4-6-2012
    rickthescot wrote:
    Sounds like a great idea. I guess asking for pictures again is not going to persuade you though. We are visual creatures and I don't think 1000 words will accomplish what one image will. You can do it, just one pic.
    More pictures that I took a few days ago to post pictures of my solar panels, and their mounts. Some pictures are really close up pictures of the solar panel mounts, and give a clear picture of howrough the surface is.
    Golden_HVAC wrote:
    Hi,
    This is my front pair of panels. 120 watt mounted on a curved roof, 102" wide.
    This is the mount it is held on with three rivets into the frame, and then the bottom half is 6" long aluminum, with nutsert in the upper piece, bolt you can not see from the outside edge pointing inward.
    This picture shows the bigfoot panel mount sold by RvSolarElectric for $35 a set back in 1994. I wonder what they cost today?
    This picture shows the panels tilted while I was working on the roof.
    Fred.
    I would like to note that the wiring is really small. The original pair of 45 watt panels, shown tiled to the right at 90 degrees was installed with #10 wire. I used the same wire for the additional 75 watt panel, on the class C, and all of this was transferred to the Bounder in 96. The forward pair of 120 watt panels have their own #10 wire with about 15 amps feeding down to the SB 50 MPPT controller. Back then a SB50 cost was around $350! That was when I was making considerably less money each hour! Minimum wage back then was only about $5.
    The cost of solar has come way down since the 'early days'. Now places like [/url=www.sunelec.com]SunElec.com sell panels for nearly $1 per rated watt. I recently looked up a 140 watt panel with frame suitable for RV use at a cost of $229. My 75 watt panel cost $375 back in 1995! The original kit of pair of 45 watt panels, wiring, bigfoot mounts, tilt arms, and controller cost $750 in 94.
    Still I figure that I saved well over $3,000 in camping costs, even if I only saved $10 a night. I did dry camp more than 300 nights between 94 and 2005. And between 2005 and 2008, an additional 300 nights +. In 2008 I started working again, but lived in the RV, without turning on the battery charger, and stayed that way until 2013.
    Solar is GREAT, and saved a lot of money in my case!
    I make my own roof brackets out of 6" long 2" angle aluminum, with 3 holes 3/16" and #10 screws into the roof, and 5/16" hole for a 1/4-20 bolt and nutsert into the panel and frame of the panel (as shown above.)
    Good luck on your own solar projects!
    Fred.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
