Cobra21
Feb 19, 2018Explorer
The only thing that should be metal is the hot water heater. Your water tank is most likely plastic, as well as the plumbing. Drain your water and try a different water source. Also boil or warm some cold water on your stove (not through water heater) to see if it still has a metal taste or smell.
Brian
Brian
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
