naturist
Feb 19, 2018Nomad II
It is also possible that the bacteria growing in the water heater are the source of the problem. Check the anode first, if you have one, and if that doesn't do it, it is time for a sanitization of the water system, particularly the water heater.
Don't be squicked out. Even city water, which is disinfected, contains bacteria. And if you've been using well water, which isn't treated with disinfectant, it also ALWAYS contains bacteria. They are everywhere.
Personally, I prefer the use of a quart of hydrogen peroxide to the usual cup or so of chlorine bleach for sanitizing my water system. It does not create tastes of its own, and is easier to flush out when after the necessary 24 hour treatment cycle.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
