Old-Biscuit
Feb 20, 2018Explorer III
SoundGuy wrote:rockhillmanor wrote:
Sometimes all I do is open the drain plug and turn on the water and let the water blast out. Then shut off water and Use a turkey baster and fill with vinegar and/or bleach while plug is open an then turn water back on and let it blast out again. That cleans out the bottom of the tank which is a good couple of inches that does not drain out.
Using a Water Heater Tank Rinser works quite well at flushing debris out of the tank. :B
Only issue I have with those wnds are you have to stick them in thru the drain hole which then is blocked by the wand,.......especially on Atwoods which only have a 1/2" drain hole. Works a little better with Suburbans 3/4" drain hole.
Remove drain plug
Stand back..turn water supply on FULL
Let it BLAST away
Hit it couple times and the scud is BLOWN out
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
