MEXICOWANDERER
Jul 04, 2016Explorer
The object of using a three phase rectifier placed alongside far away batteries is that such a setup allows the exact same amperage potential as if a user used 3/0 wiring from alternator to batteries.
Who the hell in their right mind wants to recharge (read the prefix RE- again) a bank of batteries with a measly thirty amps? A 3-phase rectifier would allow for example a hairpin 270 amp alternator to charge six or eight 3-cell batteries at 200+ amps. Call it 6-1/2 times as fast during the bulk stage.
Ooooooo but WAIT that's not all (infomercial)!
Relieving the 270 amp alternators internal rectifiers of 90+% of their amperage affords dramatic cooling of the entire alternator system, including a vulnerable voltage regulator.
When I start Quicksilver, the Niehoff is pumping 400 amps. Do I "trust" Niehoff's rectifier bridge? Hahahahahahahahahahahaha. No. That $5,000 alternator is going to be babied.
Do I have massive 4/0 cables running beneath? No. I have 3 four gauge wires.
Oooooo how about the size of the external rectifier heat sink? It's 3X the size of the Niehoff, well away from the Cummins.
For crying out loud, instead of guesswork, refer to ANY data sheet for ANY diode or rectifier and note thermal DERATING of the device. Do you suppose alternator button, dish, or press-in rectifiers are any different? One last step. Find the rating for the "diodes" (rectifiers) in YOUR alternator. Only in your freakin' dreams are those rectifiers going to stay below 220F when the alternator is working hard. Muse the point that the alternator is sucking heated radiator air PLUS radiated heat from the engine THEN adding a gross vf which translates to watts of heat THEN WAIT THERE'S MORE! The poor stator windings run at 300+F degrees - which is well beyond tolerance level for wire insulation.
Now compare this to someone at a REMOTE campsite (save your noise complaints) starting an engine cold WITH HOOD UP and recharging batteries more than FIVE TIMES AS FAST as with the finest 50 amp converter the world has ever seen. 180 minutes versus 36 minutes. Is I getting through to you? The alternator is yawning, rectifiers 150F cooler. Regulator more than 40F cooler. The stator will heat but with hood up, it's temp will be much cooler.
I don't camp in an RV refugee center. So I yanked the genset, and sold it. I it's too hot I climb mountains, laughing about spaced saved, missing weight, depreciating value of equipment, noise, and even fuel. how much generator and chargers ya think are gonna cost to develop 200+ amps of charge? You sure as hell ain't gonna lift it in-and-out.
This scenario is for SOME RV'ers and certainly not for a majority. It would be great for someone who has enough solar power to be able to shut down the engine when amperage decreases to say 30 amps. Obviously this for high usage camping. Some folks can camp using thirty amp hours per day.
Spending four grand for generators and "smart?" chargers for use at a remote campsite is not my bag. To add insult to injury, all that krap has to run for hours on end and in the end fail to complete it's mission. Oooooo then we have to change oil and filters and maintain a frickin' zoo of controls and worry about "They only want three hundred dollars for a new control board".
An optimist says a cup is half full
A pessimist claims a cup is half empty
An engineer proves the cup is twice as big as it needs to be
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
