KendallP
Apr 20, 2022Explorer
Gjac wrote:BFL13 wrote:Have you ever verified what % charge you have when it says ful with your hydrometer? My batteries are not on a slide and getting a bulb type hydrometer is impossible. I'm guessing these "smart chargers" only charge to 95% SOC or so. Any thoughts about not bringing batteries up to 100% charge does for battery life over time?
Yes, you have to do a second run after the first time it says FUL. Confirm real full with an hydrometer
The 1093A has 2a setting but the 1093D has 4a as it's low and for the E. A near full batt accepts more like 4a going to the 15.7v E so 2 as low not enough
Ha!
Man did YOU come to the right guy. You won't find anyone on these boards with more documented experience with this than BFL13.
He's basically answered everything already, but I'll break it down a hair...
1. If you do a single, modest cycle... say 75% SOC... and then a recharge with a Vector... and float it for quite a number of days... then you might get it back to 100% as could be hydrometer verified. But this will be the case with any voltage-controlled charger like your on-board converter or charger, only probably worse.
2. Then there's the whole stratification thing. Fewer bubbles with 12V hybrid batteries, so stratification is more prevalent. BFL used to remove his and tip them to combat stratification... until yours truly talked him into GCs
3. The short answer is to recharge them with the Vector and then poke the equalizing button. Unless it's really hot outside (Vectors are temp compensating,) you'll likely want to open the negative to isolate the bank from the coach... to protect the circuitry of your appliances
But how about a general rule of thumb for someone like you who can't get at them with a hydrometer...
For each 50-90 charge you performed camping... run at least one equalizing charge with your vector.
That said... we haven't talked about the "Reconditioning" mode. I haven't employed that in many, many years, but I recall believing it made a difference. However... unfortunately the Vectors don't give a float charge at the same time as the pulsing. So this is where you reconnect the negative and let your on-board converter or charger float them. Either way... pulsing should have no ill effects like equalizations can. And you'll probably need to run several 24 hour sessions. But do note that pulsing does nothing for stratification.
Or you may want one of those pulse conditioners that runs off your battery power. Those work fine so long as you're plugged into shore or solar... which you should be in storage. I doubt they draw much power when you're offshore, so I believe you can leave them connected 24/7.
Here's a search on the subject. Confirms my belief that it seems to work.
