- pianotunaNomad IIIOh the days of visiting the surplus bin. How I miss them.
- MEXICOWANDERERExplorerIt's phenolic black. And 2" from tip to base. A honker.
- NinerBikesExplorerGit 'er done, boy! You could have at least included the Rooster Beaker knob on top in the picture, slacker! ;-)
- MEXICOWANDERERExplorerFound this little Surplus puppy at Hal-Ted Electronics in the Silicon Valley. I got it because it is 20-amp Mil-Spec rated. 2-poles one for each Megawatt. Rotary of course. Snap Action which means when turning the chicken-head knob spring pressure builds until finally SNAP it clicks to the next position. Mil Spec rated for one million cycles. Ten dollars. Made in USA by Americans who will probably vote for Donald Trump. Actually it's new-old-stock meaning the people are probably passed away.
Getting all this unplanned stuff jammed into that SOLA case is becoming a task. - westendExplorer
Jack_Diane_Freedom wrote:
Powers the tin foil hat.
Negative on that.
It is a multiple pole switch that he uses to interrupt power to the local store, his daughter's house, and the nearby Pemex refinery. ;) - Jack_Diane_FreeExplorerPowers the tin foil hat.
- SCVJeffExplorerA stackable wafer.. Wonder what that's from?
- JiminDenverExplorer IIIt's that switch Mr Wizard turned him on to.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
