- MEXICOWANDERERExplorerI tried to find a Lucas switch for the Mega but they have become obsolete. It's the 3-position label I coveted
SMOKE
SMOULDER
IGNITE - Grumpy374Explorer
MEXICOWANDERER wrote:
They became obsolete when the SNAP, SNAP kept waking the DW up.
Grumpy exactly when did they replace the Sheep Grease (lanolin) with ninety weight gear oil? What a rook! Ain't nuthin better than pork grease mixed with sheep grease. Lacquer thinner? Modernist! Mineral spirits lasts longer. Use with 0000 steel wool to put a polish on the flivver that'll knock their eyes out!
And remember, ****** the spark lever BEFORE getting out. Beats getting hurled up over the hood.
In truth, if you use mineral spirits it becomes a completly different formula that was used in muffler bearings and bushings, found in early exotic sports cars like the English Ford Cortina, Honda 600's, and early Honda 50 Mopeds.
The blinker switch was very reliable. The blinker wires each, seperately, connected to an individual terminal in the switch. The shaft connected to a small pump with an intrigal fluid resivior. Lines then ran to each blinker for fluid supply. The faster the blinker blinked, the more fluid was pumped to it.
The main reason they were discontinued was when cars began to be equipped with the 4-way emergency blinkers. When they were used, the switch couldn't decide which blinkers needed the most fluid, and shut down.
By the time a suitable replacement was invented, it had been replaced by a tranducer operated switch that was vacume operated.
Grumpy
I forgot to mention, their still available through Yugo Warranty Parts.com. When they stopped being used here, the entire supply was sold to Yugo Inc.
Grumpy - NinerBikesExplorerIt's missing a Hahnenkamm
- MEXICOWANDERERExplorerKRAPP! I keeps forgetting RHEETARD is a neu-neu in the tech forum. Would it be better the refer to things as making the spark timing "Fashionably Late"?
- MEXICOWANDERERExplorerThey became obsolete when the SNAP, SNAP kept waking the DW up.
And remember, ****** the spark lever BEFORE getting out. Beats getting hurled up over the hood. - Grumpy374ExplorerHard to find. Originally found in old Army Surplus Stores next to cosmoline remover.
Supply has pretty much dried up, but it's easy to make...
Quart of 90 weight gear oil
Lb. package of lard, room temperture ( can use Crisco if lard not available)
Pint of lacquer thinner.
Mix it up and there you are. Multi viscosity blinker fluid.
Grumpy - SCVJeffExplorerWhat is it? looks like a Make Before Break UPS bypass swx ?
- MrWizardModeratorGrumpy
where do you go to buy your refill of blinker fluid
my blinker fluid reservoir is getting low - Grumpy374ExplorerThat, everyone, is a shaft driven blinker fluid control switch. It controls the variable fluid viscosity valving in the lines leading to the blinker fluid resivoir.
Generally found in older motor homes manufactured prior to 1973, but could have possibly been retro-fitted to newer years as they were known to be more reliable than the newer pressure controlled switchs that replaced them.
Additionaly, they were found to work equally well controling the windshield fluid output on early model Yugo's.
Grumpy - MEXICOWANDERERExplorer****-A-Doodle-Doo
Chicken head knob image comin' atcha Niner around 1930 hours.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
