profdant139's avatar
profdant139
Explorer II
Jul 12, 2017
Mfr used plumber's putty on window -- do I need butyl?
I just removed the front window on my trailer (cracked due to thermal stress) and took it to my local glass shop. They replaced the glass with tinted tempered glass, custom cut, for $135 -- that seems like a great price!
So now I am getting ready to reinstall. I asked the glass guy how to remove the butyl around the window frame. He looked at me funny and said, "That's not butyl. It's plumber's putty. Easy to remove with a putty knife and mineral spirits." (Obviously, I am not an expert.)
He said that he often uses putty to reinstall RV windows and said it is easier than butyl tape.
So I am confused. I thought that butyl tape was the only way to go with an RV window. But the manufacturer clearly used putty, and the window had no leaks at all. Plus, it was quite an effort to pop the window out of the hole after taking off the inner frame -- I had to make a little curved putty knife out of a scrap of steel in order to free the outer frame.
So that is my question -- should I use butyl tape, or just stick with what I know has worked on this window? The surface to which the frame will be mounted is smooth fiberglass, not wavy aluminum like my last trailer.
Thanks in advance for your thoughts! I am putty in your hands. (Not really, but I had to use that line.)
    Is that _exactly_ what he said? Because, it sounds more like he's using "butyl" to refer to the very sticky and hard to remove butyl caulk, not butyl tape which removes about the same as plumber's putty. Being a window guy, he may not be familiar with the difference between butyl caulk and butyl tape.
    I wouldn't use plumber's putty for sealing an exterior window - over time it dries out more than good quality butyl tape.
  • If you look up glazing compound,(Google- Glazing Compound) you will find that it is very much like plumbers putty. The purpose is to primarily prevent water and air intrusion, however it also provides a minimal thermal break and absorbs minimal shocks as well.
    Putty tape, plumbers putty, glazing compound are basically the same thing with the same purpose.
    The main thing is to NOT use any type of adhesive. If you do and have to replace the glass in the future...well you will see why real quick that you do not want to use adhesives! You will cut your hands trying to unstick the glass shards from the frame. And that must be done completely or you will not have a good seal...
    In truth, the fellow that told you plumbers putty probably didn't know or remember 'glazing compound' as that is the actual name for the product.
    I hope that helps. Good luck!
  • Through the years I have used the putty tape that comes in a roll from the RV shop. It has a backing on one side to keep it from sticking together. The backing obviously gets peeled off when used.
    Never had a problem with longevity.
    My thought is that it is not the plumbers putty that comes in the plastic container that you roll out in a snake and apply it around such things as sink drains.
    The consistency of those products would kind of resemble each other. :h
  • If I remember correctly, the rope caulk looked and felt a lot like plumber's putty after it was applied and the backing removed, but it has been years since I have used any.
    I did not even know there was RV putty tape! I will check into that.
    And yes, this was really plumber's putty, and yes, that is how it came from the factory. But that does not make it right!
    Thanks again for the tips. What a great forum! (That was a non-ironic comment, by the way.)
    WE sold Shadow Cruiser and I worked on them. It is NOT Plumbers Putty. It is probably the RV putty tape. Doug
  • I did not even know there was RV putty tape! I will check into that.
  • 1. Either the window had been replaced before and they used Plumbers Putty
    2. The window had what looked like plumbers putty
    3. BUTYL or RV PUTTY TAPE is the only way to go. Doug
  • Was it plumbers putty or was it rope caulk? Rope caulk I can understand plumbers putty not sure about.
  • I would use butyl tape before plumber's putty, but I suppose either would work. Are you sure it came with plbs putty, or just going with what the glass guy said? Just seems to me, that the putty would compress too easily, when tightening window frame, making it a thin seal.
    Jerry
  • Each has a particular purpose for which they are fine for.
    Butyl tape will hold up much better to any kind of movement and heat and that's what I would use for the window.
