rodwha's avatar
rodwha
Micro Air A/C Initial Amp Draw Reduction
I'm curious who's installed and used these and what they've thought of it, especially with a smaller (~2000 cal watt) generator.
Here's their videos:
https://m.youtube.com/watch?v=soP0uZFd0nQ
https://m.youtube.com/watch?v=p2K0ptvYb6Q
I had thought the small Honda generator was about all I'd likely need until I was shown the compressor startup was just too much for it.
Not only is the light weight appealing, but the quiet running aspect and fuel efficiency.
    MicroAir Report here on rv.net
  • I put one in my Coleman Mach 15 as it's 61 amp surge was causing my Magnum 3000 inverter to complain. I can say it works very well, dropping startup surge down under 30. It also waits a few seconds so the blower starts first then compressor. My Magnum has no issue starting up the AC on battery if I want.
    Was easy to install as they have a video showing it being installed in a Coleman. They seem to claim it would allow a Honda 2000 to start a RV AC, I think it might, unfortunately I don't have my Honda 2000 anymore after getting the RV with its own generator, otherwise I could tell you for sure.
  • Heh, I can't believe that I watched almost 30 minutes of that video but the guy was interesting for a tech minded person. I'm not an electrician but he sounds convincing to me.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
