pianotuna
Jul 03, 2018Nomad III
Hi,
I have the microair unit installed. It is much easier on the demands of starting the roof air. I wish the time delay for the initial start of the compressor were a little longer. Other than that, I'm a happy camper.
Before I had the microair, my autoformer would boost the voltage in "mid start". Now, with the same shore power supply the autoformer doesn't boost in mid start.
When running on a Yamaha 2800 sIEB I can run in eco mode (but I could do that before with the hybrid inverter/charger in the mix)
If I had to choose between the autoformer and the microair I'd pick the autoformer every time.
The bottom line is the microair works as advertised. I'm not certain I'd buy one again because I prefer the autoformer.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
