Hi,
Thanks for the help. Mine was set to 80 vac for the drop out. I've moved it to 60.
I do know that on a 30 amp connection with the Magnum set to 24 amps, that the autoformer reacts fast enough to cut in before the compressor motor gets up to full speed. But that's no match for 1/60 of a second.
jharrell wrote:
Not sure if a Autoformer would do any good, it is just a extremely quick voltage drop due to compressor drawing huge start amps, not sure the Autoformer would even respond quick enough.
Edit: Just read the thread, look like you ran into the same issue, I really think the Magnum is too sensistive.
The setting is under Setup->Charger Settings->VAC Dropout. Page 25 in the manual has a detailed explanation.
