pianotuna wrote:
Hi,
Could you not run it before on the 2400? Any idea what the voltage was when running?
ewarnerusa wrote:
ewarnerusa wrote:
...Then the generator test -> Yamaha 2400.
Generator test was a success! High altitude blazing hot temps will be the true test though.
It was 95F yesterday and I thought I'd try another generator test run while parked at home. It was 102 in the camper and the generator started the air con with no problem. Before the compressor kicked on, the Kill-A-Watt said 124-125V and once the compressor came on it dropped to 120-121V. Volt-amps were in the 1450 range at the beginning, about a half hour later it was up in the 1600's. Voltage stayed at 120-121V. I forced through a couple cycles and each time the generator did fine.
