ktmrfs's avatar
ktmrfs
Explorer II
May 01, 2017
microair easy start results
Well, here is a summary of the microair easy start on my coleman MachIII 13.5KBTU AC.
First, the current results before installation. I had the supco soft start cap along with a 10 second time delay on the fan start.
Measured Peak current required to start is 60A,
Results with a single honda 2000
At low altitude, lower temps, with everything else off in the trailer, and the honda eco start OFF.
If I was lucky, the honda would struggle and start the AC, but note something to count on. The honda really struggled. above about 1000Ft or above about 85F, SOL, no way would it start the AC.
With honda 2000 in parallel,
If both had the eco throttle on, usually the honda voltage would drop low enough to have the Progessive Industries EMS relay chatter, even with the PI in bypass mode, voltage was dropping way low,
If one was off eco throttle, then it would start the AC without issues.
So, here is data after the easy start install. Which by the way was pretty straightforward, good instructions. And the easy start removes any start cap on the AC unit, but there IS a start cap INSIDE the easy start, along with the control board.
starting current on a 30A service using the 5 starts recomended before using a generator
No easy start 60A
easy start 1 27.6A
easy start 2 21.5A
easy start 3 22.4A
easy start 4 25.3A
easy start 5 25.0A
now, connected to a honda 2000 in eco mode,
no load honda Voltage 126V RMS
starting voltage sag 116V RMS
running voltage 123V RMS
peak starting current 22.0A
and the generator ramped up the rpm as it started, no overshoot in rpm, start was smooth.
So, IMHO success. We shall see when it hits 90F and 4,000 Ft to see if it will still start in eco mode, but I suspect it definitely will start fine with eco mode off.
Now, all that said, if you want to run the AC and much else you still will be out of luck. the easy start doesn't defy the laws of physics, so running current is still the same, so not much headroom left. But if you run honda's in parallel, running them in eco mode should work just fine.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Just bought a TT. We have not yet decided whether to buy a generator or not. If we do, I will order the EasyStart that I have bookmarked in my browser.
    BTW, the EastStart video says it has a 5 second delay. When the fan starts, the EasyStart delays 5 seconds before letting the compressor begin to start.
  • What his excellent report also shows is what an outstanding piece of engineering the Microair Easy Start represents.
    Way to go .... both ktmrfs and Micro Air Corp.!!!!
    Now ... combine the Micro Air Easy Start with one of the new high efficiency 13.5K RV rooftop air conditioners ... and a single little Honda 2000i just might really shine at any temperature and altitude with Eco mode off or maybe on.
  • Even though both the generator and air conditioning are way out of my line of expertise, may I offer my praise at a fine piece of documentation. Not only displays your results but the efficacy of the concept. :)
  • My agastat is sitting on the shelf since I went Dometic digital.
    If you need it and are going to actually use it let me know.
  • pianotuna wrote:
    Hi Kt,
    Thanks for the information. I've ordered a unit. I'm hoping that with the kit the Magnum inverter will not display the red overload light.
    let us know how it turns out. I think you have a good chance. If possible see if you can find a time delay for the fan. I had an agastat time delay, but I believe it has been discontinued. It allows anything from 0.5 seconds to 10 seconds of delay, hooks into the 12V control line for the fan, and is adjustable by a resistor. 1Mohm gives 10 seconds.
  • Hi Kt,
  • Thank you for the effort and the post. We're looking at the Easy Start kit for our annual week long reunion at Lake Siskiyou in Northern California. They've been replacing the 30 amp plugs in our campground loop with 20 amp plugs. Don't know if our spot is downgraded yet. They want to get the loop back to small trailers and tent trailers. And force the big RVs to go to the full hookup sights. But the loop is perfect for our big family. Our new trailer has a 15k btu A/C unit, so I don't know if there is any hope. But, from what I've read about the Easy Start, it will help your A/C be less harsh on itself, it that makes any sense. So it will be a good investment.
