BFL13
Aug 01, 2018Explorer II
I will put my Kill-A-Watt on the job tomorrow. I am puzzled about the 162 amps seen on the Trimetric for what should be a 1510w input.
DC voltage was 12.0 loaded with that 162, so input was 1944w. If the 162 was really for 1620w (times 10) then that would be 1620/1944 = 83% efficiency, which as about what the inverter spec is.
No idea if the 2001 microwave is pulling more in at its old age or what. The Kill-A-Watt will say. It won't fry at under 1800w.
I will also compare a resistive load- electric kettle. Should be the same as with MSW for that.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
