Delman's avatar
Delman
Microwave removal
The Sharp R-1405 microwave in our 5th wheel crapped out a few days after the warranty expired.....of course Sharp would not give me a little slack.
So I want to remove it and find out if it's worth repairing.
The unit is built in over the range.
Would appreciate a bit of direction on how to remove it.
Thanks in advance!
  • Thanks for all the good advice.....I'll be working on taking it out tomorrow.
    You folks on this forum have always been very helpful!
    Delman
  • One method is that it's attached to the back plate only. Screws along the back bottom edge which is U shaped. Then a long flexible bolt which may be under some trim on each front lower corner that angles up to the top of the back plate.
    There may be screws on the sides or top for some installations.
    Use boards underneath so that it can't fall.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
