BFL13
Feb 14, 2014Explorer II
That's pretty much the same as the rest of the 6s out there. eg
http://pdf.wholesalesolar.com/battery-folder/charging_instruction_2011_2.pdf
The trick is to find a charger that will do that, when most converters only go to 14.4v. I use a VEC1093DBD which does normal charging to 14.8 and Equalizes at 15.7 all voltages temp compensated based on 77F as nominal
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
