Unyalli
Feb 14, 2014Explorer
BFL13 wrote:
That's pretty much the same as the rest of the 6s out there. eg
http://pdf.wholesalesolar.com/battery-folder/charging_instruction_2011_2.pdf
The trick is to find a charger that will do that, when most converters only go to 14.4v. I use a VEC1093DBD which does normal charging to 14.8 and Equalizes at 15.7 all voltages temp compensated based on 77F as nominal
That document states 14.4 bulk, not enough but far better then WFCO's 13.6.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
