pianotuna
Jun 26, 2013Nomad III
Hi choochoo,
I was uncomfortable with the load rating on the 225 tires. I've gained 300 lbs per tire.
I was tired of the tail end dragging on the least little driveway--even though I had a roller installed to protect the hitch.
The wider tires have lower rolling resistance so mileage may improve slightly
The greater diameter will change the effective rear end ratio and again should slightly improve mileage.
Most of my driving is on the prairies and it is flat land.
