pianotuna
Jun 27, 2013Nomad III
Hi Jim,
How do you mean 'relearn'?
65 in front 80 in rear--but I should check today when the tires are cold.
HiTech wrote:
The system will relearn faster it you reset the ECU by disconnecting the battery then pressing the brake for good measure, then reconnect and let it idle a bit.
But by now it has probably relearned anyway.
Good report! What tire pressures are you running?
Jim
