landyacht318
Jan 22, 2020Explorer
8k ohm is a strange value.
I've never been able to measure resistance of a pot with it still soldered in place.
I've only run one 3 wire pot in the dozens of voltage buckers that i have run remote pots on, and it turns out 2 wires would have been enough as two legs always seem to have continuity between them when I test before removal.
Is your solder perhaps bridging the contacts? I've done that before for zero voltage control effect nut was able to remove the bridge to return full function, but none were on dual sided circuit boards.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
