wa8yxm
May 29, 2020Explorer III
Mike77mastro wrote:
I have an Allegro RED and want to minimize late night and overnight generator usage when boondocking. I would like to be able to use the entertainment system overnight but don't need the 120vac only fridge or microwave. I set the inverter to cut off at 11.8vdc. Is there anything wrong with popping the breakers that control the micro and fridge overnight and then resetting them in the morning?
Might need to pop a few more breakers but if that inverter is properly wired (It feeds a sub panel that feeds the inverter powered stuff) will work fine
If you are plugging the entire RV into the inverter pop all breakers save the ones you want powered on ESPECIALLY THE CONVERTER .make 200% sure that one is off. (Double check)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
