RoyB
Dec 14, 2013Explorer II
I suspect you may using a extension cord not rated high enough for your use. My 50-foot extension cord plugged into my 120VAC 20AMP Garage receptacle is a HD 10-GUAGE Contractor (10-3) type extension cord.
I have used a 12-gauge size but would definitely NOT go any smaller than this. The RED ORANGE WALMART specials are usually 14-16 gauge size which will give you too much voltage drop especially for a 1500WATT heater.
I also always used the long dogbone type RV30A-15A adapter between the 50-foot extension cord and the RV 30AMP trailer shore power cable. The smaller black round RV30AMP adapter always got hot on me and may burn up rather easy.
I do not use these styles of adapters
You do not want your 30AMP Shore Power to end up like this photo - trust me...
Inside the trailer I like to use one of these RV 120VAC plug-in voltmeter. These have the SAFE ZONE marked in "GREEN" which you can glance at to make sure the 120VAC is within it correct level.
My 120VAC 15-20AMP Garage shore power connection story... This is what works great for me...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
