enblethen
Jun 24, 2014Nomad
The Brisk air units are rated 115 volts. You should not run them lower then 90%(103volts). Even at that other loads could drop the unit below the safe margin. I would not run it less then 108 volts.
Brisk air
The shore power should be close to 120 volts. That would put the operating voltage of the AC with 10% at around 110 volts.
Brisk air
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
