lawrosa
Sep 07, 2017Explorer
shastagary wrote:
the furnace should be fine the high temp limit switch measures the temp of the combustion chamber not the heat output of the furnace and its already sucking in 85° air for combustion from outside it does not take much to get the combustion chamber past the limit.
Huh? The high limit is inside the heat output duct box.
I dont think there is a high limit in the combustion chamber. Just the igniter and flame sensrr.
I just did another temp probe of a closer duct output and it was some 200f plus..
The intake air I was measuring temp at was the room intake around the unit itself.
The outside intake seems to be sucking in air normally..
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
