lawrosa
Sep 07, 2017Explorer
time2roll wrote:
I added two new 4" round ducts from the furnace before mine would not cycle against the high limit switch. One attached to each side of the heater box. I had lived with it 10 years before doing this upgrade. Heat is so much better now. My OEM floor ducting was collapsed giving about 70 percent restriction. I tried to prop it open but was not enough.
I wish I could see your pictures.
I think I see up to 3 ducts. Are those all added? All wall vents or is some through the floor?
Yes thats my pic. Originally there was 3. The other one you cant see. Its directly on the other side of that back wall or furnace. a 3 " piece of flex to that ductin the master bedroom.
But its offset. They did not line it up right. But that duct gets real hot
I added the duct to the couch there in front. So now there are 4.
The other two ducts are clear and not crushed. I have access to those ducts through the kitchen cabinets.
The high limit is in the middle of the front plate you see there with the one duct on it.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
