BFL13's avatar
BFL13
Explorer II
Dec 17, 2013
Mixing Batteries on Float-- Mex Test Update 2
UPDATE 1 on 23 Dec post
UPDATE 2 on 25 Dec post
Mex is driving me crazy! He said do not mix my used 12s (Scrubber batteries, he calls them--humph! They are respectable golf car batteries I'll have you know. Humph!) with my regular bank of 6s or they would evilly interact, and I would ruin my good 6s. I asked if that were still true if they were all on a Float charge.
Mex said they would still have evil interactions even when all on a Float. So I have gone ahead at some inconvenience to keep the used 12s and the good 6s apart.
Now all of a sudden, Mex pipes up in another thread with this!!!
MEXICOWANDERER wrote:
Batteries should be separated after the charging protocol. Connect all batteries together and apply 1 nominal 14.2 charging volts and there is no way any of the batteries can detect it one battery or a hundred are online, or the chemistry of any of them. The only requirement made of a charging system is that it not under or overcharge the battery. Voltage requiments for flooded 5% antimony batteries and pure lead AGM is similar enough for multiple warhead work.
It's when the charging ceases that the problems arise.
So go ahead and use a smart solenoid to parallel charge the batteries. I have done this too many times to count.
What is going on here? Are there evil interactions or not as long as they are charging or on a float? Does this leave the time they are discharging together as when the evil interactions get going?
If they are banked on solar, they discharge at night and charge during the day. So the evil interactions come out after dark? Can I just call Ghost Busters?
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 21, 2025
