I have 3 deep cell batteries. One of them is bigger (and newer) than the other 2. What happens if I try to use a big and small one together? What about putting all 3 together?
Another option for you to consider is to create two ‘banks’ of battery power by running the newer battery by itself and the other 2 (together) as a second battery.
This can be done via a cheap marine battery switch (bat. 1, bat. 2, both, off) or by just swapping cables.
The weaker batteries will cause a shorter life for the new battery. Given they are used per your other thread it's a good idea to load test all 3 to make sure they are in reasonable condition. Given that and they are available go ahead and use all 3.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
