I am purchasing a new RV and I have some questions about mixing together different panels and controllers. On my present camper I have a 140 watt Kyocera. On the new one it has a 20 watt and cheap lo...
I have used multiple controllers on a bank. They worked fine as long as both were set to the same voltages.
As far as mixing panels on a MPPT controller, that 20w panel isn't enough power to worry about even messing with in my opinion. You really need to match up the panels on a MPPT controller because it has to find the sweet spot in the array voltage and mismatched panels make it hard for it to do it.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
