Travel_glampers's avatar
Apr 05, 2021
Model PD9280A converter problems
I am trying to replace the above original converter in my fiver (with same model converter). The first attempt resulted in 0 volts DC coming out of the converter, with it being plugged into 120 volts AC (meter check shows 120 volts). The second converter, again being plugged into 120 volts, showed 8.4 volts coming out. Per the Progressive Dynamics (PD) tech, it should be putting out 13.6 volts. So I have paid to send both converters back to PD, so they can check them out. I am on my second set of new deep cycle batteries. Also have replaced land line to 30 amp house outlet, twist outlet on fiver this line hooks to, and the 120 volt 20 amp outlet the converter plugs into. Has anyone else experienced similar problems? Is there something(s) I'm missing?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
