Travel_glampers
Apr 13, 2021Explorer
PD checked both converters out. Both checked out fine. I received one back and installed it. Dennis at PD went the extra mile trouble shooting with me. Got consistent 120 volts at outlet converter plugs into (removed surge protector which showed some arching). 13.7 volts coming out of converter. Positive line running to battery compartment, hooks to a relay (I believe). The second post of the relay has a positive line running on to the batteries, with several other smaller lines hooked to it. Several years ago this thing started clicking. As it clicks the voltage at the battery posts changes from 11.3 volts to 12.5 volts, and back again. Is this caused by a bad relay? Called Jayco tech support and was told to take it to a dealer. My trustworthy dealer has retired and closed up shop, unfortunately.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
