wa8yxm
Apr 26, 2021Explorer III
Note when checking voltages in and out measure at the Converter's connections. If you measure 120 volt at the breaker.. that is no guarantee it is getting to the converter (I had that problem with my Air Conditioners. 120 volt at the termional on teh breaker, nothing on the wire stuck in the clamp as the screw was loose.. had it with my converter too, it was a 'P' Model (plug in) plug out.
Likewise measure at the converter, and the batteires. that would have found the problem "Downline" of the converter.
I also like to use test lights when I can rather than meters. Put like a one amp load on the line
Had one wire in my RV once 13.6 measured on one end. close to it on the other with the high impedeance meter... NOTHING with the light... Yup one solid length of wire The problem was about 1-1.5 feet from the battery... Cut and spliced and all good.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
