MEXICOWANDERER's avatar
Oct 10, 2016
Modifying The 36-Amp Megawatt List Of Materials
http://www.ebay.com/itm/SILVER-Thermal-Grease-CPU-GPU-XBOX-PS-HeatSink-Compound-Paste-ARCTIC-Alternative-/182020814257?hash=item2a614935b1:g:pnUAAOSwDuJWvLI5
http://www.ebay.com/itm/With-Turn-Counting-Dial-500-Ohm-3590S-2-501L-Rotary-Potentiometer-Pot-10-Turn-/121005346074?hash=item1c2c7b0d1a:m:m1IYYSqWH-yZpJN3S2CjoPA
http://www.ebay.com/itm/Helping-3rd-Hand-Soldering-Iron-Hobby-Tool-w-Vise-Clamp-Magnifying-Glass-New-/361252377824?hash=item541c51d4e0:g:hNwAAOSwHnFVzMyk
Details about With Turn Counting Dial 500 Ohm 3590S-2-501L Rotary Potentiometer Pot 10 Turn EBAY
http://www.ebay.com/itm/20-AWG-5m-Gauge-A-Silicone-Wire-Wiring-Flexible-Stranded-Copper-Cables-for-RC-/231863203455?hash=item35fc1fb67f:g:dzoAAOSwHnFVwsC3
http://www.ebay.com/itm/New-RadioShack-15-Watt-Soldering-Iron-6402051-/222272498433?hash=item33c0792b01:g:1scAAOSwNRdX9cwJ
http://www.ebay.com/itm/0-3mm-63-37-Tin-Lead-Diameter-Rosin-Core-Flux-Solder-Welding-Iron-Wire-Reel-1Pcs/151893988852?_trksid=p2045573.c100505.m3226&_trkparms=aid%3D555014%26algo%3DPL.DEFAULT%26ao%3D1%26asc%3D38530%26meid%3Dab7f7ab6b20c45ed9ccc230a867f89ab%26pid%3D100505%26rk%3D1%26rkt%3D1%26
  • Cheap digital multimeter for ohms and volts. No calculations necessary. EZ job
  • If you have some of this stuff, great, if not here are the links
  • The silver heat sink grease is for replacing the zinc oxide on the Megawatt transistors and rectifiers -EZ to do. Yes, this grease transfers heat that much better
  • The lock on the voltage adjustment potentiometer is to lock it so it doesn't move and the number help to pre-set it
  • You'll also need a decent quality #1 and #2 phillips screwdriver
  • A handy magnet to keep all the screws together
  • Some rags to wipe off the white zinc oxide grease
  • I need No.4 reading glasses. You may need stronger, weaker or none
  • The "3rd Hand" alligator clip holder is worth it's weight in headache tablets to hold wires still when soldering
  • The existing potentiometer does NOT have to be removed
  • Only two small wires needed to be soldered to the Megawatt board
  • The other end of the wires will be soldered to the potentiometer
  • Geeky language will not be used, and no assumption will be made that you have ever soldered anything. No Einstein calculations
  • This will be a step-by-step photo do-it-yourself complete with handy "why can't I?" answers
  • I am ready to read, watch and learn.
    Having to remove the existing Pot and solder the new Pot to the circuit board is what made me previously think I don't want to try that. You caught my interest when you said "The existing potentiometer does NOT have to be removed"
  • This is going to be an INTRICATELY DETAILED series with photos. So It has to be done incrementally. We have a single eager participant. Just one? No other folks interested? I would then follow up with a series on how to improve the Megawatt, from transistors, to rectifiers, to fan.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
