DFord wrote:
Sorry to say, there's no magic bullets when it comes to RV refrigerators. Make sure whoever you take it to is experienced. Your profile doesn't indicate what part of the country you're located so no recommendations.
Way back when I first learned about absorption refrigerators the only thing to try with a malfunctioning unit was to turn it upside down and let it set for 24 hours before setting it rightside up, letting it rest awhile and trying it again. I seldom worked and probably isn't worth the effort.
I turned my Dometic upside down twice in the twelve years I owned it, worked both times. this last time the cooling unit developed a pin hole from rust. Putting in a Residential.
