MitchF150
Jan 08, 2022Nomad
howardwheeler wrote:
I don't fulltime but I like to camp offgrid whenever I can. My furnace seems to be properly sized. When its cold out (20 degrees) it will run maybe 60% 0f the time. The coldest I've been is around zero and that ran 85 to 90% of the time. Looks like I need to live with it.
Well, that's a lot colder than I've ever been in while in the RV.. (maybe in the low 40's to upper 30's at the coldest).
I had the Propane furnace going for that and it would cycle about every 15-20 minutes after running for some 10-15 minutes.. Just a guess as I would eventually fall asleep, but it seemed every time I was "awake", it was running!
I only had the temp set to around 65* too... But, it was warm enough thru the night..
Even the Heat Pump I have at home does not work very well below 35* and I just switch it to aux heat (electric) at that point so it just does not run all day..
Keeping warm costs money no matter where you are at! :)
Mitch
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
