StirCrazy
Oct 30, 2021Moderator
Almot wrote:
Possible reason: confusing Chinglish of the app with no LVD but with "Discharge Limit" and "Over Discharge" instead, the former being a mystery and the latter (probably) an inept name for LVD. I thought that LVD was a "Discharge Limit" and set it at 12.6, but the LVD apparently was an "Over Discharge" (set below 12, don't remember now).
Also, settings in User-defined mode would revert back to defaults if I dial in a different battery type, ex. Gel or Flooded and then return it back to User-defined mode. If you do this, all User settings are lost - LVD would change to 11V, Boost time to 120 minutes and Temp Comp to 3C. Very dangerous. But, hey - who would ever change their battery, right?
so did you change battery types and go back and not realize that things had reverted? all the numbers you gave above looks like this happened. I wonder if it resets when you take the power off also? Ill have to play with mine and see.
Steve
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
