GordonThree
Feb 20, 2014Explorer
Mexico: Good thing you have pointed out... HEATSINKS!
I find the Chinese led boards regardless of wattage rarely have enough heatsink or even thermal mass. This goes for the plastic LED flexible-strip lights that are popular with RV crowd as well. LED + HEAT = short lived LEDs ... it matters not if it's one ten watt led or ten one watt leds or a hundred 100mW leds, the heat has to go somewhere!
Rule of thumb from a little company named Philips ... 3 sq in. of heatsink surface area per watt of LED. This doesn't have to be all on the horizontal plane, a heatsink with vertical fins adds a lot of surface area. Second thing to consider, surface area (fins) are only good if cool(er) air can move across them.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
