GordonThree
Feb 21, 2014Explorer
LScamper,
In my studies, the issue becomes a problem when you parallel very long strings of LEDs, where the forward voltage between strings varies more than a few millivolts. Driving short parallel strings of high-power LEDs is endorsed by Diodes, Philips and most other sources I have worked with.
For long strings, such as signage lighting or LED back light, each string has at least a ballast resistor, or more likely a linear regulator in series, insuring each string receives only the design current even though forward voltages vary between strings.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
