Golden_HVAC
May 28, 2015Explorer
pconroy328,
I always wondered about the 'monster cables' and have a twist on it. Besides my ears suffering from ringing all the time, I don't think I could tell the stereo set up with the monster or normal cables, even in side by side comparison.
Yet here is my question to the more electrically proficient: Would there be capacitance in the monster cables?
By capacitance, I mean that it takes a few electrons to 'fill' a #14 wire and start the electricity moving down the line. How many more electrons are required with the wire is say #2 wire, or 4 times larger? So will it take more electrical power to fill the copper lines, before it starts moving to the other end and into the speaker?
As a second subject for the electronic proficient. How large is the wires winding the magnet? So if they are using #30 wire inside the magnet, why does anyone really need #8 wire going to the connection on the back of the speaker, then to #18 wire internally to the speaker, then to #30 wire (or whatever size it is) inside the speaker near the magnet?
I do know some people that have so little knowledge in electrical things that they would be "Happy" to spend $100 on a monster cable for the high def TV set, and $150 more for the monster cables to the surround sound system that it is hooked up to. Giving them advice and trying to convince them that only 0.01 amps is going from the cable box to the RGB receiver inside the TV set is just like blowing wind through their empty head.
That a speaker system really never exceeds 10 amps in normal use (except say a concert).
Some will never really ever figure it out. Yes you could sell them a relay that turns on and off as the battery is charged, as a de-sulfiter. It also works to charge the battery (takes twice as long because it is off so many minutes per hour, but it will charge it someday)
Have fun!
Fred.
Have fun!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
