dougrainer
Sep 01, 2018Nomad
1. You need to state Brand and Model of Refer
2. Regardless of Brand and Model, IF the refer fails to LITE on LP, you should have either a CHECK Light or a LP error code
3. Have you tried to put the refer ON LP ONLY? I assume you have it on AUTO.
4. Genset or SHORE, the refer will work on 120 as long as other 120 appliances are working on Genset
5. When was the last time you did maintenance on the refer? Clean the burner and such? Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
