jplante4
Sep 01, 2018Explorer II
Does it switch to LP on the control panel?
If so, do you get a check light?
Did you purge the air out of the propane lines by running the cooktop?
Have you checked to see if crud came down the stack and is sitting on the burner?
Does the burner try to light?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
